And works ok for tag ==> filename.
But not work from file to extract cover. It is a bug of mp3tag?? you want that I inform of this in Bug Reports?
Now, you say:
Action type: Format value
Field: TEMP
String: $num($add(5,%_counter%),5)
Cover export:
%genre%-%comment%-%temp%
I understand this. You say me:
1st) create a sequence in temporal tag (any empty tag)
2nd) use this sequence for extract cover and rename
3rd) format the sequence in the temporal tag (erase 1st step)
It is correct?? But, how write it please !?
1st) ¿?
Action: ?
String: $num($add(5,%_counter%),5) ==> temporal tag where I type?
2nd) ok. I do it this:
Action: Cover export
3rd) ¿?
Action: Format value
String: $num($add(5,%_counter%),5) ==> temporal tag where I type? Or I type only this in the place empy of "Format value"?
You can show me how to writte the 1st and 3rd step pliz!!??
I have not understood you, sorry! I'm a little dummy! hehe I don't know write an generic format of expression for use "format value". I don't know where you write tag TEMP. I have found the "action type" but I assume that it is for erase tag not for generate or write anything. But my problem was that I don't know generate a sequence into the field. Never before I used this action...
But you don't worry because I found an alternative
tag to filename:
%genre%-%comment%-$num($add(%_counter%,VALOR),6)
Action: "Formatear valor" mean "erase field valor"
Action: "Eliminar campos" mean "erase field valor"
The translation is not correct!
Where say "Formatear valor" should say "Dar Formato Al campo" for indicate well it is for modificate a tag, not for erase. Formatear in spanish is how "format c:"
