How to edit zip files?
Hello. I was wondering how to edit files that are zipped. They only seem to work if the files are in a folder. I tried looking in the settings but I can't seem to find much. Thanks for the help advance.
(Do you speak about the music files you can see in the windows file explorer where you click on a zip archive?)
If you want to add or modifiy or delete metadata in your music files, you have to unzip them first.
Yes, I'm talking about those. How do I unzip them?
In Windows explorer: Right-click on zip file > Extract all.
For simple unzip windows explorer would be ok,
but have a look on freeware 7zip.
You like to compress again after editing? Why? One Zip per Folder?
What fileformat are you using?
