How to eliminate one character from beginning of title?
i have a title like this>
aHandfullofwater
i want it to be like this>
Handfullofwater
how can i accomplish this task?
i have found out the answer.
RE-^.{1} will do the majic. thanks to the forum
You have the choice ...
Cut First letter case ignored.
$mid(%TITLE%,2,$len(%TITLE%))
$right(%TITLE%,$sub($len(%TITLE%),1))
$reverse($left($reverse(%TITLE%),$sub($len(%TITLE%),1)))
$regexp(%TITLE%,'^.',)
Cut First letter if lower cased.
$regexp(%TITLE%,'^\l',)
Cut First letter if not lower cased.
$regexp(%TITLE%,'^\L',)
... to read the manual and try out what you want to accomplish, the tools are ready made for you too.
DD.20100201.1515.CET
I want to mention, that above written "First" has the meaning of starting reading at the left side of the string (the orientation is LTR=LeftToRight but not RTL=RightToLeft).
DD.20100202.1118.CET
thanks for the suggestion. but i could not understand --$regexp....in your quotecut first letter if lower cased-$regexp(%TITLE%,'^\l',)
where to find that? do u mean replace with regular expression replace string? if it is so then , i have to put those inside the parenthesis as the regular expression. am i right?
I've discussed your theme of "having no knowledge how to use the hammer from the toolbox" already there:
how to replace the fourth underscore to a dash?
evergreen1, please take some time and read what other users have asked and what answers they got. You will find many new insights for yourself by understanding the problems of others.
DD.20100202.1027.CET
