How to execute a script in mp3tag
Hi all
I've been learning about the powerful scripting language of mp3tag.
I have an example here
$ifgreater($len(%title%),30,This title is too long!,)
This basically adds "This title is too long!" to the %comment% tag if %title% is greater than 30 characters.
But where do we execute this script.
I also use the below in the export config
$loop(%_path%)%genre% $loopend()
Can we use similar scriots to modify tags? If yes where do we execute it?
Thanks in advance and appreciate your patience
Export scripts create external text files - so they do not change anything in the tags.
See the HowTo-FAQs on how to create a new action:
To assign a value to a field, use an action of the type "Format value", in this case for COMMENT:
Yet, I find it strange to write such a statement to a field - wouldn't it be a better step to filter for such files and then run an action or something to solve the problem? Because, I mean, what will you do with the information in the comment?
This filter would show you the files with longer titles:
"$ifgreater($len(%title%),30,yes,no)" IS yes
