How to export all track cover to folder ?
If possible, how to save in the desired size and format and save the cover with the music name.
Thanks
MP3tag does not modify an embedded cover in respect to size or format.
See the help on the correpsonding action:
You may enter as filename
Format string: %artist%_%album%_%title%
ok, how to export all covers ?
I have some music that I need to export all covers
Select all files, execute the action
The covers are different
I can not get your point
This format string would create a file with at least the title as unique part of an album. Therefore, you would get one file per TITLE.
The problem got solved in a PM discussion:
So let us assume that the folder is called something like
d:\music\all_covers
Create an action as I described above but enter as
format string: d:\music\all_covers\%artist% _ %album% _ %title%
Run it for at least to sets of files from different folders.
Check the folder d:\music\all_covers to find files like
If this is what you want, then select all files and execute the action for all of them.
