How to export lyrics?
I were added a %UNSYNCEDLYRICS% on csv but totally confused after exported.
Is anyone could leave a config for %UNSYNCEDLYRICS% ? I need to import it again(sync), from another files without lyric
THX
This might been already solved by the solution suggested here.
