How do I use the Filter to search out specific strings, like for example "/ " (no quotes)? I tried to type those characters in directly but nothing happened. I assume extra code is needed for specific strings?
Did you check https://docs.mp3tag.de/filter?
You have to use the keyword HAS, MATCHES or IS to get btter results
