Hi, is it possible to create a filter to identify tracks with unclosed Parenthesis?
ex. "(Text ("
Thanks!
ex. "(Text ("
Thanks!
Try
%field% HAS "(" AND NOT %field% HAS ")"
This is my fault...
Actually what I want to filter is "(text (text)"
Then try
title MATCHES "\(.*\(" AND NOT title MATCHES "\).*\)"
This works thank you @ohrenkino.
One more question is there any action which is able to identify and fix these tracks automatically?
I know i could use REPLACE " (" with ") (" if i filter these tracks first. Actually this is WRONG as the result would be ) (Text) (Text)
But what am asking is for an action which will be actually able to do that, Find and Replace at the same time.
(Text (Text) to (Text) (Text)
For a pattern where you assume that you always (if at all) miss the first closing bracket, you could run this Format value action:
$replace($regexp('(Text (Text)','(\(.*)( \(.*\))','$1)$2'),'))',')')
if all the brackets are there, you simply get the already existing string.
"Text" was just an example i was trying to show the format of the tag.
So actually i am trying to find a way to fix these tags independently of the "Text" inside the brackets
I thought it was obvious that you replace the text constant with the field variable for the real expression.
Sorry but my mind doesn't work right now
So is there any way to do that independently of the text?
could look like this:
$replace($regexp(%title%,'(\(.*)( \(.*\))','$1)$2'),'))',')')
Thank you once again @ohrenkino.
I tried something similar but it didn't work, as i said it's a tough time for me...
Cheers mate!!!
This filter will return tracks with Open parenthesis even if there are more parenthesis following
ex. "(text (text) (text)" or "(text (text) (text) (text)"
%Title% MATCHES "\(.*\(" AND %Title% MATCHES ".*?\(\w*?[^\)]*?\("
Also these actions would fix the open brackets for the examples above
"(text (text) (text)" to "(text) (text) (text)"
$replace($regexp(%title%,'(\(.*)( \(.*\))(.*\))','$1)$2$3'),'))',')')
"(text (text) (text) (text)" to "(text) (text) (text) (text)"
$replace($regexp(%title%,'(\(.*)( \(.*\))(.*\))(.*\))','$1)$2$3$4'),'))',')')
