Hello, is it possible to search songs for multiple copies of front album cover?
Sometimes I'll see songs that will include 2 (usually two different resolutions) and I have to manually remove one. Can I find the ones I may have missed?
try a filter
%_covers% GREATER 1
Or if you are looking for a specific type of cover
%_cover_type% IS Front Cover
or
%_cover_type% IS Other
AFAIK this only checks the cover type of the first existing embedded cover, not the second or additional ones.
Thanks for the filter ideas, I've used it to catch some dupes.
