I want to insert a lowercase letter as the fourth character in a list of filenames. I thought I put the right string in, but it just gives me the same letter (in this case 'a') over and over again. I want the letter to increase by one for each file. So track 2 should have a 'b', track 3 a 'c', ect.
This is what I used: A1.$char($add($num(%1,1),97)) %2
The lowercase letter comes after A1.
The 97 indicates the lowercase 'a', but what am I not doing right to get that letter to increase for each file?
You could try it with A1.$char($add($num(%TRACK%,1),97))
you should replace %2 with the content of another tag like %TITLE% or %ARTIST%.
This would produce A1.b A1.c A1.d
If you want to start with the lowercase letter a, you should start with the value 96 instead of 97.
In my test, I load 3 tracks, choose Tag -> Tag for _FILENAME and use the above format string and it works as expected.
As said, I don't have your %2 as I don't see how this could work and where the content should come from. But it does not repeat the same character. It start at a over b to c If I use 96 instead of 97.
You would have to supply the original filename, the pattern you used for the original filename and the pattern for the target filename.
If A1 is the %1 part, then $num(%1,1) will always return 0 as value.
Okay, I see part of the problem. I wasn't doing it in Tag - Tag. I was doing it in Filename - Filename. The %1, %2 ect. values don't work in Tag - Tag, do they?
I should've mentioned which conversion section I was using. I used your code in Tag - Tag and added %TITLE% and got the result I needed. Thank you.
