action case conversion
i want the first letter of the first word in the title in the upper case and others in lower case. i tried all the option in the case conversion but failed. i have titles with leading digits. the sentence option also gives me the lower case. mixed case gives me the first letter of each word in upper.
eg> 101 Pari Malar
wanted to get it as> 101 Pari malar
thanks
Action "Replace with regular expression"
Regular expression:
^(\d+ .)(.*)
replace with:
$upper($1)$lower($2)
Use the converter "Tag - Filename" , or an action "Format value" on the field _FILENAME, with the following scripting expression ...
$left ( %_filename% , $strchr ( %_filename% , ' ' ) ) $caps3 ( $cutLeft ( %_filename% , $strchr ( %_filename% , ' ' ) ) )
Use the converter "Filename - Filename" ...
Convert | Filename - Filename | ALT+3
Select format string
Old filename pattern:
%1 %2
New filename pattern:
%1 $caps3(%2)
Preview
101 PARI MALAR.mp3
To:
101 Pari malar.mp3
DD.20120423.1535.CEST
thanks . it works. have a nice day.
DetlevD:
%1 %2
%1 $caps3(%2)
Preview
101 PARI MALAR.mp3
To:
101 Pari malar.mp3
thanks a lot for the reply . f/n-f/n tried and it works. have a nice day.
