suppose i have created so many actions. when i format the system all those actions will be lost. what to do to get back the actions which i created >without doing those actions afresh is there any options through which i can get back those actions? like saving some spl files from the mp3tag. and put them in the installation directory when i install the software afresh.
Menu > File > Save Configuration...
Creates a zip-archive with all configuration files.
After formating your system you have and re-installing mp3tag you have to replace the new configuration files with the ones from the zip-archive.
I never had to do it, but I think that's how it works.
thanks for the reply. have a nice day/
