How to hide certain files from filtered results?
Hello Everyone,
I have set up a filter to get Mp3tag to display all the files for which the %year% tag is missing, namely:
%year% MISSING
However, at the same time, I want it to hide certain files from view, in this particular case to hide the
files that contain in their %title% field, the following string:
  1. (HTOA)
Note: There is a space between the dot and the opening bracket in the aforesaid string.
Eventually, I gave up trying to achieve the desired result, having read and applied many variations of the following filter:
%year% MISSING NOT %title% MATCHES "00. (HTOA)"
Please, show me where I got this wrong?
Thank you, I always appreciate your assistance.
Try
%year% MISSING AND NOT %title% HAS "00. (HTOA)"
From the documentation, about AND / OR / NOT
From the same documentation about MATCHES
Thank you, both.
Certainly always reading first, but as certainly, not always comprehending.
@ohrenkino:
The above filter did not hide the string.
This one eventually did:
%year% MISSING AND (NOT %title% HAS "00. (HTOA)")
Really?
Logically, it does not make any difference at all whether you apply the brackets or not. You have 2 conditions that should become true.
It would be different if you had 3 or more conditions out of which a pair should be evaluated together.
@ohrenkino, you are correct indeed. I am unable to explain why it did not work the first time around, but when reapplied, your filter worked perfectly. Thank you again.
