How to insert a line break after a character
How do I create a line break after a character? in this case ;
Currently I have the pone script as so for performer field.
\u000A-----------------------\u000A works find and look as so:
Album Credits:
Double Bass: Chuck Israels
Drums: Paul Motian
Engineer [Recording]: Bill Schwartau
Piano: Bill Evans
Producer: Orrin Keepnews
However in those cases where Discog does not have metatag and i create my own tag info...
I would still like to it be the same.
Not sure if an action can occur here, but simply I would like it to read when there is a ; add a line break.
Example where i add my own info
Flora Purim - Vocals;
Moriata - Percussions;
Bill Evans - Piano;
Need it to read as:
Bill Evans - Piano
Any ideas...
Thanks
Begin Action Group _Script Test#TEST
Action #1 Actiontype 5: Format value Field ______: UNSYNCEDLYRICS Formatstring: $regexp($regexp(%unsyncedlyrics%,(;$|;([\r])),$1\r----------------------------),;$,)
End Action Group _Script Test#TEST (1 Action)
it works with the exception it does drop down a line.
Flora purim - vocals------------------------
Moriata - Percussion-----------------------
Bill evans-----------------------------------
Need it to drop down a line
Bill evans
thanks
I think the \r should be expanded to \r\n (see Help on scripts)
That's it... Thanks
Got it added a \n made all the difference.. thanks for your help
Funny that. That same code worked for me. Glad to have helped.
