So I'm using the Apple Music script by @AreDigg it writes all the tags I want. I just want to skip the composer tag and retain my own custom tag. I tried using "keep" in the composer edit field but it doesn't make any difference, composer tag from the Apple API gets written
So how can I do this? any help will be greatly appreciated.
Thanks.
Thank you for the response @Poster. Sometime I need it, other time don't so I can't edit the script. When I rip from CD, I need the script to write the composer tag while when I purchase from Qobuz I get the composer tag in the file in that case I just want the script to skip that particular tag as Apple also includes artists and featuring artists, if any, in the composer field which I don't like. I like the way Qobuz handles the composer tag, they only have the real composer in the field so I prefer their value in the field.
Create an extra script for the use without composer.
Save the changed file in the same folder with a changed name, e.g Apple Music Web without composer.
Then edit the the apple country src-files you use in the third line. This line stands of including the inc-file, you just edited and saved with another name:
Include]=Apple Music Web without composer.inc
and save it to Apple#Music ... without composer.src.
