How to merge Artist + Title into "Title" field?
Hello, i tried to google and didnt find any answer.
I only wanna MERGE artist + title into TITLE field like this:
%artist% - %title%
how do I do that?
Thanks.
Here's the way I accomplish the task:
Format Value
Field: Title
Format String: %title% - Featuring: %artist%
you can remove the Featuring... I use it for ex: Ascension - Featuring: Kirk Whalum
can you please explain it step by step ? im new with mp3tag
So you should get aquainted with mp3tag.
For your problem you could start reading the FAQs
/t/967/1
only that you use the string
%artist% - %title%
