If you are sure that the year-part is always the leftmost bit then you could use an action of the type "Format tag field" for the the field YEAR:
Enter as format string
$left(%year%,4)
this leaves the left-most 4 characters.
Beware of dates that looks like this:
31.12.1977 the result would be 31.1
so perhaps you filter your tracks first to make sure you hit the right ones
%year% MATCHES ^\d\d\d\d.
