How to put text in to Cover Metadata
I have noticed in some mp3 files sent to me, that there is text next to the image in the 'Cover' - this is a sniipet of a screengrab:
Clip0001
You can see that the usual info is there next to the image:
image/jpeg
640x480
157 KB
Front Cover
and then below data there's PMEDIA
I can drag & drop the image to a folder. If I then right-click + R (in MP3TAG) to remove the image and Save the file Neither the image nor the PMEDIA legend are there.
If I then drag the saved file back into the mp3 the image is there, but the PMEDIA legend is not.
How does this work ??
How can I do similar with my MP3s ??
Thanx in advance for you help.
cheer BJ
This can be found by right-clicking on the album cover, and selecting “Set cover description…” in the menu.
Many thanx.
I'm noe educated once again :slight_smile:
cheers BJ
