Is it possible to recreate the following action in Mac OS version?
Correction
Field: TITLE
Correction: Normal
Word start to/from every: (-_./"[
Thank You in advance for any suggestions
Correction
Field: TITLE
Correction: Normal
You can create action for a Mac.
Did you have a look at the documentation?
On Mac, I haven’t found the same windows action I need.
I found “Correction” action but with only two fields. The windows version has 3 fields and I can’t “copy” the same action on Mac cause 2 fields only.
So I’m searching for an alternative Action to have the same result
The Mac version of the Case Conversion action is actually a little bit smarter than its pendant on Windows. The characters you've listed above are automatically treated as word begins on the Mac.
Great
I will try this action! Thank You
