Hi! How to remove back picture and waveform picture? field "picture" and "cover" erasing all images from mp3 files... how to remove 1, 2 or 3 picture?
If you have a set of files with the same set of covers you can either use the tag-panel and its display or the extended tags dialogue.
In the tag-panel right-click on the incriminating picture and select "Delete cover".
Repeat until all unwanted pictures have been deleted.
Press Ctrl-S to save the changes.
In the extended tags dialogue you can press the red x for "delete" next to the display of the picture to delete it.
"OK" then saves the changes.
