I have many songs which have () or [] in Filenames and Titles. (There is no text in the brackets).
Is there a way to remove these brackets.
Thank you.
Thank you.
Create an action of the type "Replace" for e.g. TITLE
Search string: (
Replace String:
(leave empty)
Create corresponding actions for other brackets and other fields.
Thank you so much, it worked great
Cheers!
Have a look wether there are white spaces left.
In case of white spaces in front or behind the brackets you have to modify your action.
