G'day, I need to remove part of the Title in a number of songs.
for example: Current title is [Jumping Jack Flash - Mean Streets]
I would like to remove "- Mean Streets"
I now do this manually for each song but if I had to do many of these, can I automate this in some way?
Something like select the 10 relevant songs, in the title field, enter [ remove "- Mean Streets"]
If you recommend using a script, please kindly tell me how to use the script in mp3Tag.
Thanks in advance, OR
dano
2
Are the brackets part of the title?
Is it always " - Mean Streets" or do you need a general " - some text" ?
Thanks dano,
No, the brackets are not part of the title. I used them as simply brackets to separate the title of the song from the sentence.
I need " - some text". Mean Streets was just an example.
Regards, OR
dano
4
Make a new action:
Action type: Guess values
Source format: %title%
Guessing pattern: %title% - %dummy%
Thanks Dano. This worked but with slight change
In Guessing Pattern, I used %title% - Mean Streets which worked. %title% - %- Mean Streets% did not work.
Thanks again, OR
dano
6
I wrote %title% - %dummy%
so use exactly that.
%dummy% is a special field. You can use it to discard everything at its position.
That worked just fine..
I didn't know %dummy% is a special field. I thought you meant "dummy" as in variable.
Thanks once again, OR
Thanks! This is trick works friggin great!
So much time saved.
xmjpgx
9
Awesome, thank you so much sir.
This was brilliant! I used it for an audiobook that had 93 files. So glad I saved myself an hour of manually updating the titles.
