I installed mp3tag with this option checked, then later reinstalled it with the option unchecked. Unfortunately, that didn't remove it from my right-click context menu.
How do I remove it permanently?
Do you use foobar2000 as player? If so, you can use the following file. Simply save it as "Remove MP3Tag Shell Extension.reg" and run it:
Windows Registry Editor Version 5.00
[-HKEY_CLASSES_ROOT\Directory\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.aac\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.ape\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.cue\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.flac\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.m3u\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.m4a\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.mp2\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.mp3\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.mp4\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.mpc\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.ofr\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.ofs\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.ogg\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.spx\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.tta\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.wma\shell\Mp3tag]
[-HKEY_CLASSES_ROOT\foobar2000.wv\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.aac\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.ape\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.cue\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.flac\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.m3u\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.m4a\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.mp2\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.mp3\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.mp4\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.mpc\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.ofr\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.ofs\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.ogg\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.spx\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.tta\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.wma\shell\Mp3tag]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\foobar2000.wv\shell\Mp3tag]
If you use another player, you might need to replace the "foobar2000.*" strings with something else.
