How to remove semicolon ( ; ) from artist
Hello..
I just want to know how to remove or replace a semicolon from artist section.
Some track contains multiple artist name for example: John;Doe;Newman
I want to replace that semicolon ( ; ) with a comma ( , )
so that it will look like:
John, Doe, Newman
I've already tried Action->Replace
but not working...
Any solution ?
Then you have to check the parameters that you entered. Perhaps there is a space character in the wrong place.
I forgot to mention something.
In Windows Explore it shows like John;Doe;Newman
but when I take those files on mp3tag. It shows like John\\Doe\\Newman
Screenshots:
I don't know what to do.
... which means that you have a multi-value field (several fields of the same type).
You can merge these to just one field with an action of the type "Merge duplicate fields".
Enter the "comma blank" as separator and it should be the way you want it.
I don't understand why you guys are so AWESOME !!! :smiley:
THANK YOU SO MUCH
IT WORKS
