I have a bunch of songs that begin with 01 & 02. (note the .) track numbers at the beginning of each songs filename. Is there an easy way of removing this?
Thanks
(Example songs)
09. Pink Floyd - Have a Cigar
11 - Donovan - Sunshine Superman (how can I remove the first hyphen but leave the second?)
ad 1: Do you want to have the dot replaced with a space character?
ad 2: Do you want to have the first hyphen replaced with nothing and should there remain two spaces between the track number and the artist?
That's easily done, but are you sure that you want the track number removed from the filename? That generally results in a folder full of files that are sorted by somthing (only track title) that isn't very useful.
