How to remove track numbers from filenames?
I have track numbers preceding filenames in hundreds of files. eg
01 - Billie's Bounce.mp3
01 - Any Time.mp3
Can anyone tell me how to remove these numerals other than manually. I have hundreds of them.
Any help much appreciated.
Thanks
gmilne
gmilne@telus.net
There are many paths which lead to Rome...
If you have the title tag field filled in, you can use the Tag-Filename assistant with "%title%" as formatstring.
If not, you can either use an action which formats the "_FILENAME" field using this string: "$mid(%title%,6,$len(%title%))" or create a RegEx action which replaces "^\d* - " with nothing in "_FILENAME", as well.
Thanks man. I owe you.
Your first suggestion worked a treat. I didn't understand the 2nd.
If you ever get to Vancouver you can reach me at gmilne@telus.net
/g
