Yurei
April 10, 2021, 1:09pm
1
Hello I have a problem.
my Title-Tag looks like:
"Peter Clines - Dead Moon - The beginning"
and my Album-Tag and my Artist-Tag look the same.
How can I remove the unwanted text in the Tag?
The result should look like this:
Title-Tag : The beginning
Artist-Tag: Peter Clines
Album-Tag: Dead Moon
Can i use that for that?
Action type: Replace with regular expressions
Thx for your help
This can be done via a (Quick) Action Import tag fields :
Import tag fields
Source format: %title%
Formatstring: %dummy% - %dummy% - %title%
The same can be done for artist and album, where you'd use the respective placeholder for the source format and adjust the position of the %dummy% placeholder, which is used to ignore specific parts upon importing.
Or even shorter:
Formatstring: %artist% - %album% - %title%
where you distribute the data to the other tag-fields - provided one tag field has the full scope.
