Hi! How can I rename my all songs in base a website or plugin? Thank you!
There is the function Convert>Tag-Filename with which you can rename files with data from the tags.
It is not quite clear to me what you mean with base, website or plugin.
You can get additional data from freedb.
You can use a web source (script) to get data from websites..
Yet, all the data mining methods usually require that you already know artist and album.
