Hello,
I've used MP3tag with great success organising my whole music library. But now I run into a seemingly simple task which I can't perform, because I probably doing something wrong, but I don't know what .
Most of my filenames are like this: "02 - ", but some are like: "02; " or: "02. ". Now how do I rename all my filenames to the first mentioned format?
Thanks
Stanray
Well, you could perform a "Replace action" for _FILENAME. that replaces the offending character with the correct one.
Or you use the converter TAG-FILENAME and a mask like this:
$num(%track%,2) - %artist% - %title%
You could run something like this:
Begin Action Group _Script Test#TEST
Action #1
Actiontype 5: Format value
Field ______: _FILENAME
Formatstring: $regexp(%_filename%,^\d+\s*-*\.*;*\s*(.+),$num(%track%,2) - $1)
End Action Group _Script Test#TEST (1 Action)
Its gets all the text string after:
'02 - '
'02; '
'02. '
And replaces it with TRACK padded with 2 numbers and then - $1 (What has been captured after the 3 things above.
DetlevD
November 9, 2012, 10:44am
4
This proposal does not need any tag-field value, but just the filename ...
Convert | Tag - Tag | ALT+5
Select format string
Field:
_FILENAME
Format string:
$regexp ( $regexp ( %_filename% , ' ^(\d+)[ ;.-]+(.+)$ ' , ' 00$1 - $2 ' ) , ' 0*(\d\d)(.+) ' , ' $1$2 ' )
... or ...
$regexp ( ' 00 ' %_filename% , ' ^0*(\d\d)[ ;.-]+(.+)$ ' , ' $1 - $2 ' )
Preview
01 - song one.mp3
02; song two.mp3
3. song three.mp3
04 song four.mp3
5 song five.mp3
To:
01 - song one.mp3
02 - song two.mp3
03 - song three.mp3
04 - song four.mp3
05 - song five.mp3
Testfiles ...
20121109.stanray.renumber.zip (1.77 KB)
DD.20121109.1242.CET
stanray
November 12, 2012, 7:48am
5
Thank you so much all, very helpful.
Problem solved!
Stanray
Ok and what about
01 Hold on to Love
To
01 - Hold on to Love (don't work)
Thank you
Both formatstrings work as designed, try again.
DD.20160321.1929.CET
I tried it with both formatstrings and it makes no change
Ok i found the issue
i placed originalfilename instead of filename
it works now
sorry for the mistake
Thank you again
Martin
