case: complete filename= 12..34..test..mp3
In the above case i want to separate the last two dots by a space character. Without changing the %title% field (= 12..34..test.)
desired operation per single action would be:
filename.extension= 12..34..test..mp3 -> 12..34..test. .mp3
i cant get this one to work...
any tips?
What about an action of the type Replace for _FILENAME_EXT
Search string: ..mp3
Replace string: . .mp3')
Blimey
3
If I understood your question correctly, this should give the wanted result.
It works in 2.56a.
%title%
(add a single whitespace character at the end of the string!)
Cheers,
Blimey
tried that already as single action and quick action, doesnt work
Blimey
6
It doesn't change the %title% value.
