How to send and drag & drop files to an audio editor? -OR- Problems with running as (not) administrator on Windows 10
I recently went from Windows 7 to Windows 10. And I have this problem: I can no longer drag and drop files from Mp3tag to Sony Sound Forge audio editor and I also cannot send them to it from via the Mp3tag File > Options > Tools feature
The problem comes to this: one software is run as administrator and the other is not. At least that is the explanation that I have found on the Internet to this apparently common problem with various pieces of software; and which explenation is confirmed by my tests
On my system I have one User and that User is the administrator. I have Mp3tag pinned down to the Windows Taskbar. The Mp3tag icon on Taskbar has 2 playlists pinned to it. And by default it works like this: if I want to open Mp3tag I can either left click the main icon on the Taskbar or right click the very same icon to unfold the short menu- and then left click one of the two playlists or the additional icon for the Mp3tag EXE itself. So after that, in either case, if I have files in the main window of Mp3tag and want to select them and drag them to my audio editor I can do that only in theory- because in reality nothing will happen [except for an occasional show up of the hour glass for a split second]. Also if I execute the simple File > Options > Tools entry
Path: C:\Program Files (x86)\Sony\Sound Forge 7.0\forge70.exe
Parameter: "%_PATH%"
then also nothing will happen. My actions are simply ignored. And both of these methods were working on Windows 7 without a problem. But there is a solution to this; kind of...
If I right click the Mp3tag icon on the Taskbar and then also right click its icon from the mini-menu, I can go to its
Properties > Shortcut > Advanced > Run as administrator
and select the box for that. So now what happens? If I left click the icon on the Taskbar [or right click it and the left click the sub-icon] Mp3tag will open- and I can drag files to my editor from it. And I can also execute my File > Options > Tools shortcut. So, the problem is solved? Well, not exactly
Because if now I will right click the icon on the Taskbar to see the menu and left click a playlist from it- nothing will happen. So now the task of loading of the playlist is ignored. And there is no
path for the playlist to be tempered with- at least not accessible in the same way as in the case of the shortcut to the EXE. So I navigated myself directly to the
C:\Program Files (x86)\Mp3tag\Mp3tag.exe
I hopes of selecting Run as administrator for the EXE, instead just for the shortcut. The path to came out to be different, because it goes like this
Compatibility > Settings > Run as administrator
So, problem solved? Not exactly
Because:
A] Now if I right click the icon on the Taskbar and then left click a playlist from the mini-menu, I will get an pop up question from the User Account Control, prompting me if I want to execute it. So Mp3tag icon works and playlist icons work- but the latter ones now in an inconvenient way. It is simply a drag to re-click that UAC question every single time when I want to load up a playlist from a shortcut
B] If I want to play files from Mp3tag in my Winamp, I can double left click a single file in the main window or select in the main windows multiple files and use the Play option from the right click menu- and then have to wait for about 20 seconds before Winamp will finally start to play the loaded data. And what is also interesting, during this 20 seconds Mp3tag works half-way, e.g. I can execute an Action but then will have to wait for the Mp3tag Toolbar icons to regain their colors thus indicating that the options from the Toolbar are no longer blocked [by that sending process that last ~20 seconds]. And what is more interesting, if in these new conditions [with Run as administrator applied directly to the EXE] I drag and drop the files to Winamp from Mp3tag, there are loaded into the playlist immediately
The same thing [the "B]" that is] happens with FreeCommander file manager: I cannot drag and drop files from it unless FC is opened as administrator- and when it is, it takes ~20 seconds for a file left-clicked in FreeCommander to be played in Winamp and during these 20 seconds FC blocks itself [but completely and not just kind of like inthe case of Mp3tag]. So I should also run Winamp as administrator- and the problem will be solved [because I will have an administrator combo consisting of tagging, file managing and audio playing software]? Not exactly
Bacause if Run as administrator is applied to the Taskbar shortcut of Winamp- playlists pinned down to Winamp Taskbar icon will be opened in new instances of this software; and when Run as administrator is applied directly to the EXE of Winamp- the same User Account Control drag will be happening as with playlists pinned down to Mp3tag icon [that "A]" thing]
So you see: this is getting ridiculous. This problem solved in such way in one place / software pushes it to another place / software. [And in the future I might want / need to expand my software combo by some additional program, thus continuing this run-as-administrator cascade]
And before I ask for solutions, three things I must point out, that might be beneficial to resolving this matter
1] How is it possible that Winamp not run as administrator will after ~20 second succumb and play a file send to it from a software [like Mp3tag or FreeCommander] that is being run as administrator? My good old Sound Forge does not succumb at all. And why does Winamp not need 20 seconds when files are dragged from a software to it, but immediately lists them in a playlist when there are dropped?
2] Sound Forge is not run as administrator- at least not to my knowledge. Its EXE file does not have the Run as administrator check box selected, just like a shortcut for it that was placed in the Menu Start. Why does Mp3tag [and FreeCommander] when not run as administrator apparently want to open Sound Forge as administrator [I assume, because if they would try to open Sound Forge not as administrator then the files would be send to it without a sweat, right; and I wolud not have a need to post this?]
3] In comparison I can send files to spectrogram software called Spek from both Mp3tag and FreeCommander, no matter if they are run as administrator or not. But that is because Spek does not install itself, but it is just an EXE ready for usage as it is. The File > Options > Tools entry for it goes like this
Path: C:\Windows\System32\cmd.exe
Parameter: '/Q/D/U/C START "SPEK" /MAX "C:\Program Files\Spek\spek.exe" "'%_PATH%'"'
So my questions / solutions would be:
I] How to run every software as administrator? And why is not every piece of software already being run as administrator if I am the administrator User of the operating system?
II] How to run all playlists files as administrator? Or how to run as administrator just the playlists pinned to the icons of software pinned down to the Taskbar [as I do not use playlists other that these particular ones and in that very exact way as described]
III] How to get rid of the User Account Control pop up questions? On Windows 7 once a software was allowed to be run by the user, it stayed with that privilege for good. But our good old Microsoft had to improve things by treating us as idiots, that cannot be trusted with the choices we make
IV] How do I check which software at a given moment is being run as administrator and which is not? I do not see such info in the Task Manager
I am using Mp3tag 2.97, FreeCommander XE 2019 Build 790a 32-bit public, Sony Sound Forge 7.0 Build 214 and Winamp 5.8 on Windows 10 Enterprise x64 18362.239
Some picked out answers to your veeeeery long post:
Security reasons. Have a look at the access rights for folders and files. Your "Administrator" user is only one of the many possible users who should have access (others are "Trusted Installer", "System" and some more).
Type uac in the search field (magnifying glass in Taskbar) and adjust your needed level of security. Everything lower then "Standard" increase the risk of unauthorized access from a virus and malware.
Choose the tab "Details" in the Task Manager and search for your app, like Mp3tag.
Then you can read the actual user name in the column "username" and check to see if it is running with Elevated Privileges. You can choose which columns should be displayed by right clicking on one of the column headers.
I would seriously check the ownership of the files.
Esp. if you have a new installation of the OS but the files reside somewhere else, it is most likely that you are not the owner anymore.
Being administrator is not enough.
some technical backround:
https://docs.microsoft.com/de-de/windows/win32/api/winuser/nf-winuser-changewindowmessagefilterex?redirectedfrom=MSDN
but it's not recommended, see
https://blogs.msdn.microsoft.com/patricka/2010/01/28/q-why-doesnt-drag-and-drop-work-when-my-application-is-running-elevated-a-mandatory-integrity-control-and-uipi/
Thank you all for answers and sorry for the delay on my part
In conclusion it says there that
"The best solution is to only use drag and drop between the same MIC levels."
So if my audio editor
but my Mp3tag and FreeCommander are not, will making them on the same level solve the problem of getting rid of the pup up question from UAC?
[That would be a first solution]
I tried using some UAC "managers". For example UAC Trust Pal did not work at all while UAC Trust Shortcut did work. But all the seem to do is to create a neat shortcut to an EXE file. And such shortcut work in that they open the software but I am unable to really utilize them as I am not able to incorporate them into my modus operandi- i.e. the end result is opened editor without a file a not the file selected for opening in that editor shown loaded to the editor. In other words: sending of the file triggers the software to be opened and indeed the software is opened without the UAC question but without the file already loaded to it- and that beats the purpose of the whole shebang
[That would be a second solution]
I also tried this solution UAC trusted apps open as admin without confirmation | Freeware Downloads | TheFreeWindows but apparently all it did was to trigger my editor to be opened after entering Windows. [And now I cannot stop it from doing it even after deleting that Task - but no need to worry, this issued will be gone when I restore my operating system form an image]
[That would be a third solution]
Those two approaches above are also similar to what I have been trying to do by the means of utilizing BAT files and Task Scheduler entries before I started this topic. All I got was neat shortcuts that were nevertheless useless because after incorporating them into FreeCommander [i.e. after trying to use them for the SEND-TO-THUS-OPEN-EDITOR operation] they were opening the software without file in them
As for
all I get there is an overall slider with 4 options, varying from "Always notify" and "Never notify"
And after choosing the lowest possible security option I can now send files from FreeCommander to my editor without that annoying intermediary question; while at the same time when I try to install a software a still get the pop up warning, which I did not expect to be still getting but of which fail-safe I am fond of. And I am not worried about my security after that change also on the behalf of using use the free and basic version of COMODO which monitors all activities within the system [like one file trying to access some software or system's process]- as I assume that it is more likely that hackers will try mingle with UAC and not with COMODO, because hundreds of millions of people use Windows but only a percent of them are using COMODO
But still that did not solve the problem of me not being able to send files to the editor from Mp3tag
[That would be, and for the time being is for now, the fourth solution]
As for
I do see this relevant at all. Because I was already in the past able [before the fourth solution] to send files to the editor from FreeCommander and I am also able to [with fourth solution in place] do so now, while Mp3tag stays deaf to my Tools shortcuts. ERGO: it is the Mp3tag that has some extra issue with Windows 10 when it comes to sending files to my editor
Or is my logic assumption false?
The "Tools" function in MP3tag makes a system call to execute something with the given parameters, some kind of shell command.
So, open a command shell and enter the same command that you use as tool call as a single command line. You would have to fill in any kind of variables as the command shell does not know them.
I wonder if that works.
or whether you get an error message.
not a problem of mp3tag, see techical articls.
Open a few shell windows on different users (for example using sysinternals psexec) and see what happens.
I think I have found what is suppose to be a complete list of commands for the: CMD The Complete List of Command Prompt (CMD) Commands. Unfortunately none of "send" or "open" words in this document is in a section of text describing operation of sending files to a software or opening it with a desired file
So I do not know how I am even to begin transcription of my C:\Program Files (x86)\Sony\Sound Forge 7.0\forge70.exe and "%_PATH%" from Mp3tag Tools entry to the command line, as I do not know what command to connect them with
I assume that this is exactly what @ohrenkino is advising to test out? Except taken one step deeper?
And not knowing what that sysinternals psexec is it would be easier and quicker for me to just create new users on my system? Or take my backup machine in form of a laptop hosting also Windows 10 and perform the same basic test on it that @ohrenkino speaks of?
You don't need a special command. You just use your forge70.exe and manually enter all thats needed (path, File, Parameter). I don't know if your piece of software is capable to do this what you want. But if it does not work in the command shell it will not work as a tool od MP3Tag.
So that is the test which Ohrenkino wrote of.
To create a command shell command line e.g. to get MP3tag to open a particular folder, you would enter this:
c:\programs\mp3tag.exe /fp:"C:\Users\Musicuser\Music\Ambient Diary.Three - 2000"
in MP3tag the same command looks like this:
Path: c:\programs\mp3tag.exe
Parameter: '/fp:"'%_folderpath%'"'
So find out how a command line for your target program would look like and then split it up into path and parameter.
Are we still on the same page?
Running in CMD
"C:\Program Files (x86)\Sony\Sound Forge 7.0\forge70.exe" "M:\Music\Some Song.mp3"
opens Some Song in Sound Forge. But that ability was not questioned by me
The Problem is this:
On Windows 7 in Mp3tag a Tool like this
and in FreeCommander a Favorite Toolbars icon like this
Program or folder: C:\Program Files (x86)\Sony\Sound Forge 7.0\forge70.exe
Start folder: %ActivDir%
Parameter: %ActivSel%
was sending a file to Sound Forge [first opening it if needed]. But on Windows 10 only FreeCommander is still able to do this. [And sending files from FC to Mp3tag also works on Windows 10 as it did on Windows 7 and showing in FC a file selected in Mp3tag also still works]
So abilities of Sound Forge are not the issue here; I think
And I completely do not understand how opening
or inability to do so will make any difference? I need to send a file: a single selected file or a group consisting of my selections- done in Mp3tag
So in CMD
"C:\Program Files (x86)\Mp3tag\Mp3tag.exe" /fp:"M:\Music\"
Opens the aforementioned Some Song file in Mp3tag- but that takes me nowhere near what I seek
But I tried mixing the old Tool with the new one into
Parameter: /fp:"%_PATH%"
but it also does nothing, just like the a clean "%_PATH%"
And is this by every means correct
Or did formatting of your post got messed up and there is too much of all that
in it?
The way you edited the quote led to a different formatting which may lead to syntax problems.
Please see the help on command line parameters:
If you are unable to use this information in conjunction with your favourite file handling program then please contact the support of that program.
This topic here gets boring for me. Do not expect any further replies on it from me.
