Hello, I have mp3 tag for mac and I wanted to know how to do this? It's that I did it a long time ago but I don't remember how I did it. in the mp3 tag program, manually order the songs in the order in which I want them to sound on my usb in the car, my question is how I have to do so that the number of the songs appears in that order and that they remain labeled like this; 01 - shakira - monotony? if you can help me please. THANK YOU
I attach an image so you can see how I have it
Here are some steps I'd perform to have the files renamed as desired:
1. Fill in missing information
Now fill in manually the missing information for the two tracks at the top (01... and 02...).
Also make sure that all files have the Artist (Interpréte) field filled in. If they don't please let me know before you proceed.
2. Remove track number from title
I'd first remove the number from the Title (Título) field by using a quick action Actions → Quick Actions → Import Tag Field (Acciones → Acciones Rapidas → Importart campos de etiqueta) with
Source Format (Formato de la fuente): %title% Format (Formato): %dummy% - %title%
For example, track 4 should now show El Tonto and not 04 - El Tonto.
3. Reorder the files manually
Hold down the option key ⌥ and move the files in the desired order.
4. Rename the files
Now rename the files using Convert → Tag - Filename (Convertír → Etiqueta a nombre de archivo) with Format (Formato)
What do you want to save?
Which program would do the sorting on the USB by which criteria?
If it is the filename, then you would have to have filenames that can be sorted the way you want the result to look like.
If the sorting program sorts by the embedded tags, fill these.
If the sorting program can read playlists, save a playlist with the correct order.
