Filename: Jay_Mexx_-Plastic(Original_Mix)_[Deep_Records-DRS245]
Need output: Jay_Mexx_-Plastic(Original_Mix)_[Deep_Records]
How to use $trimRight for remove "catalog number" from filename, including "-" ?
Maybe:
in: %1[%2-%3]
out: %1'['%2']'
How to make this action for batch processing?
For sure set Mp3tag Filter to ...
"%FILENAME%" MATCHES "^(.+?[.+?)-.+?(])$"
... then apply "Convert Tag - Tag" ...
... or Action "Format value" ...
Field: _FILENAME
Formatstring: $regexp(%FILENAME%,'^(.+?[.+?)-.+?(])$','$1$2')
... or ...
in case of the trailing sequence has always the same length, ...
Field: _FILENAME
Formatstring: $cutRight(%_FILENAME%,8)']'
DD.20161231.1313.CET
Big thanks, DetlevD!
Field: _FILENAME
works fine!
How add whitespace character in your formatstring?
i have mixed files... for example:
Jay Frog - Dream (Original Mix) [Groove Records-GR054]
etc...
