How to uninstall?
Using windows 10, I installed Mp3tag v2.93 and it seems that it successfully installed because it was up and running. However, Mp3tag doesn't show up on windows program list and I have no way to do clean uninstall to try again....is there an uninstall utility available?...if not, please advise how to uninstall...
You've probably used the portable installation option, which simply installs in the folder you provide (without leaving any other traces on your system). If so, you can simply delete that folder.
If you've used the standard install option, you have the entry to uninstall under Windows Settings > Apps.
