How to use CSV file to add ISRC codes?
Hi, is there any way to import ISRC codes to songs by using CSV files? Our radio channel has many many CD´s which now have been ripped to mp3. Now we need add ISRC codes which are needed for music licencing companies when we report them what we have been playin last month.
If we start to do this one by one for 25000 songs, it will take a while :slight_smile:
best regards from FINLAND
kuhan.fm
Yes. Have a look at the feature "Import Tags from Text Files":
