How to view custom tags in music files
Hello,
I had taken a great deal to trouble to customise existing tag fields by renaming them to suit classical music.
Unfortunately, I had to reinstall Windows without losing data, but had to install all applications once again including mp3tag.
My music files contain the tags. Is there any way I can see them in order to restore the custom names within MP3Tag?
Many thanks in advance
See the extended tags dialogue Alt-T
If you refer to the customized Tag Panel or customized columns in the File List:
You would need to use a previously safed configuration settings ZIP archive.
Backup and Restore Configuration
To backup your configuration settings, please choose File → Save configuration.
To restore the backup, unzip the backup archive to the folder that opens when you choose File → Open configuration folder. Close Mp3tag before copying any files to ensure that all files can be written.
Thank you immensely! Saved me a lot of grief!!
I can now do the needful and save the configuration file as @LyricsLover suggested.
Thanks to @LyricsLover as well!
