How to visualize iTunes "group" column on MP3tag?
hello verybody,
I need to change all the tags I wrote on the "group" column in iTunes, but it do not show up in the software. Could you please help me? I download Mp3Tag just for this and I am quite upset! I hope there is a way, thank you very much!
Fabio
Check the extended tags dialogue with ⌘T and see which field name is used for the data.
The add a column for the field in the file list and/or that field in the tag panel as described in the documentation
Thank you very much, Ohrenkino,
I manage to add the "Grouping" field.
The action that I have to do is copying all the info from "grouping" to "album field. I did it with the function "import or copy tag from tag", and it worked out.
But now, if I open iTunes, the "album" field has not changed.. How to visualize now on iTunes the changes?
Thank you very much for your patience, I am a total ignorant on this topic.. thank you so much
Fabio
see e.g. here:
thank you so much for your precious help,
many blessings,
Fabio
@Fabio A word of caution!
I use the grouping field extensively in iTunes. Please note that this is saved in different tags, depending on your file types.
mp3 files use the tag field %grouping%
m4a files (lossy or ALAC) use the tag field %contentgroup%
MotleyG, great tip thank you very much!
Fabio
