Okay, as the title says, how do you work with multiple genres? I'm a very detailed person and want my music to be categorized correctly. I'll give an example of my situation:
I mainly listen to metal, so I'll use that as a good example, because it confuses me more so than any other genre. And the music program I'm using is foobar2000. The band "Red Fang" according to metal-archives is Stoner Metal and Rock. So initially, this is how I tagged it: Metal\Stoner\\Rock. This is how it shows in foobar: you can see how tagging other bands shows up as well
I don't find that to be correct [this applies to other bands as well]. I wanted them to appear as separate genres. So if a band has multiple genres (e.g., Doom/Sludge metal), they'd show up under each one individually --- not "Doom, Sludge" as one genre. It occurred to me that Rock is the umbrella genre and that things should look something like this:
How would I go about tagging bands this way in mp3tag and it showing correctly in foobar? can it be done? or am I better off just placing each band with one genre and going about it that way? A good example that also has me baffled currently is the band "Kadavar", they're Stoner Rock (metal), Hard Rock and Psychedelic rock. I'd rather them be tagged with each genre as I showed in the example. I don't know how to just... pick one when they have more than one genre incorporated in their music. Is this even possible?
Thanks for any feedback.
