How to write ID3v2.4 TSST frame?
hello,
i'm trying to get mp3tag 1.7.8 (79) to write the ID3v2.4 TSST ('set subtitle') frame to an MP3 file.
i've configured a tag mapping for this from DISCSUBTITLE (which is how i refer to this tag in Vorbis comments):
i've configured the tag in the tag panel:
i've added the 'Disc Subtitle' tag to a file:
this all appears to be working fine. however, if i inspect the file's tags using Mutagen (a Python music tagging library), it looks like Mp3tag actually wrote the subtitle to a custom frame called 'TXXX:TSST':
>>> from mutagen.id3 import ID3
>>> a = ID3('Blutengel/2009 - Schwarzes Eis (Limited Edition)/CD1 - Schwarzes Eis/01 - Behind The Mirror.mp3')
>>> a.keys()
dict_keys(['TALB', 'TPE1', 'TPE2', 'TPOS', 'TCON', 'TMED', 'TPUB', 'TIT2', 'TRCK', 'TDRC', 'TXXX:STYLE', 'TXXX:DISCOGS_RELEASE_ID', 'WXXX:', 'TXXX:CATALOGNUMBER', 'TXXX:COUNTRY', 'TXXX:TSST', 'APIC:'])
>>> a["TXXX:TSST"]
TXXX(encoding=<Encoding.UTF8: 3>, desc='TSST', text=['Schwarzes Eis'])
how can i make Mp3tag write to the correct TSST frame instead?
You have to chose the correct Mp3tag-internal field (SETSUBTITLE) in the tag-panel.
aha: i removed the tag mapping, and instead added a tag mapping for DISCSUBTITLE > SETSUBTITLE and now everything seems to be working fine for both FLAC and MP3 files.
thanks!
