I cannot figure out, just how to write something as simple as [what you would read as]
pause minus pause
Or in other words: how to insert into a post a new line which starts with a pause, then is followed by anything and then it ends also with a visible pause?
I always get the pauses removed; or a block of text completely re-arranged / formatted. The old forum had this option for block of code, where you could write exactly what you wanted and with many pauses
