I have searched and read the "How To/Help" section but I still seem to be missing something.
I have used MP3Tag for years but I have never needed to use any custom actions. I am trying to add a function to the Rename Files Based on Tags feature.
What I do is have is it simply list TRACK & TITLE. What I need it to also do is remove illegal characters for when I move music to my Android Walkman (example, ?, * etc).
I kept trying to use $validate and it just kept adding validate to the track name. I saw where I needed to use both validate and replace but I don't understand exactly how to set that up to run as an easy one click and go. I have no idea what I'm doing so any help is appreciated.
Create an action of the type "Format value" for _FILENAME
Format string: $validate($num(%track%,2) - %title%),_)
Try that first as I think that the asterisk is handled by $validate()
If you need further characters then try
Format string: $replace($validate($num(%track%,2) - %title%),_),\,_)
(and add all the dubious characters and their replacement after the last underscore, all separated by commas)
The help says the follwoing:
Remove invalid characters from file name/file paths
Command: $validate(filename,to)
Example: $validate(%artist% - %album% - %track% - %title%,-)
This example replaces all invalid characters (/?*"<>|:) with dashes.
BTW: the same could be achieved with Converter>Tag-Filename - so if you feel uncomfortable with actions, use the converter.
Thank you, I am still messing up somewhere. I am selecting "rename files based on tags" from the tool bar. But if I input that command what it creates is: "$validate(track title,-)"
Example: 02 Is That Okay? becomes $validate(02 Is That Okay?,-)
It is my understanding I need to run both validate and replace if I want to remove illegal characters and question marks.
I can get replace to work however. If I enter $replace(%TITLE%,?,) it will create: 02 Is That Okay (having removed the question mark and not leaving the word $replace in the title).
Thanks and sorry for the trouble, I'm just not sure what I'm doing wrong.
This statement has no reference to any field variable. They have to be enclosed in % like %title%.
No. You see a list of "validated" (=removed or replaced characters) in the list from the help that I quoted.
Why don't you try one of my suggestions and see whether they come closer to what you want?
Thank you. I think I am seeing where I am going wrong. Let me try to dig with what you have given me.
