Hello i have a lot of FLAC and WAV music folders and since i reinstalled Windows 11 a few cover arts are not showing anymore. When i load them into mp3tag, they are there. I tried to clear the thumbnail chache, and removed the arts from the files and attached new ones but nothing works for them. All the others works just fine.
THe Windows Explorer is famous for its problems to deal with metadata in files in flac or wav format. It would be best to install a plugin that can deal with those files better.
See e.g. here:
You do not say which player has problems. But perhaps there also a player that has better support flac and wav would be the solution.
Thank you so much, icaros worked just fine. Now i remember that i had this shell extension before I reinstalled Windows 11 too.
