Mefu720
September 16, 2019, 8:43pm
1
Hi. I want to automatically tag my forever expanding music library. I used to do this by hand, but it took like forever.
During doing this by hand I came up with a comfortable scheme that I would like to somehow apply to a program to do the job now, example:
File name:
{author name } - {song name } {(Ft. names )} {[name Remix]}
Song Metadata:
Title:
Contributing artists:
{author name , author name , author name }
Album:
{album name }
Album name for singles:
{song name } - Single
Year:
{year }
And that's all the info I want tagged on a song, all the other stuff like comments, genre, number, etc. should be deleted
The thing is, I have no idea how to do that. So here I am
Do you want to import data from the filename?
Then see
How to import parts of the filename into the tag?
Importing tags from filenames and directory names can be done by using the [Converter > Filename - Tag] Converter > Filename - Tag.
The basic concept is the notion of a format string which describes the structure of the name to import from. The format string is built of either standard text (e.g., Music), placeholders (such as %artist%, %title%, ...), or backslash characters \ that denote directory structures.
Here is an example that imports t…
Do you need some help on getting your hands on MP3tag?
See the help:
Are you looking for external sources to complete the data?
Then see
Ready-to-use web sources and development of web sources
Mefu720
September 18, 2019, 9:54pm
3
The Tag to Filename is pretty good once I download the data from Discogs. Kinda wish I could automate it all thought, cuz as of right now I have to go 1 by 1 and verify everything. Still, this is waaaay faster than doing EVERYTHING by hand like I usually did
You may run the converter once you have applied all the tag changes - so you don't have to repeat that for each track individually.
Tagging with the weg sources is album-oriented. So you can tag all tracks of an album in one go and don't have to repeat it for each single track.
Mefu720
September 22, 2019, 6:21pm
5
The data downloading via discogs is pretty wonky once I try to use it on multiple files, even on 2 it gets the naming wrong
As I said: you have to do it album by album.
It is not possible to use the tag sources on several albums at once.
The quality of the data in the web sources is beyond MP3tag's controle.
Mefu720
September 22, 2019, 6:31pm
7
Alright, still. It gave out wrong names after selecting 2 songs from the same album for some reason
Guess I have to have all the files from an album for this to work correctly?
No, usually you can (manually) align the data list from discogs with the filenames.
Mefu720
September 22, 2019, 6:41pm
9
Eh, guess it will be faster to just rename the files by hand then, again. The TAG - Filename is great tho
Thanks anyway. I'll ask here for help when I'll have problems with trying out the other options, cheers
