OK, you're a pro ![]()
Can you try this from an admin command prompt:
cd C:\Program Files\Mp3tag
powershell -c "Add-ProvisionedAppxPackage -Online -PackagePath Mp3tagShell.msix -SkipLicense"
C:\Program Files\Mp3tag>powershell -c "Add-ProvisionedAppxPackage -Online -PackagePath Mp3tagShell.msix -SkipLicense"
Path :
Online : True
RestartNeeded : False
Can the UAC settings be affected? I have them turned off completely.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
EnableLUA -> 0
I'll do some experiments later.
I've tried with UAC disabled on a fresh install of Windows 11 22000.708 and it works without problems.
If you're using an admin account you can also try from an admin command prompt:
powershell -c "Get-AppxPackage -name *mp3tag* | Remove-AppxPackage"
powershell -c "Add-AppxPackage Mp3tagShell.msix"
I've also just learned about Get-AppxLastError and Get-AppxLog — maybe they can shed some light into this issue?
