Hi !
My duplicated songs filename ends with: (2)
Example: ABBA_songname(2).mp3
How do I
make the program write DUPLICATED at comments field in any song ending with (2) ? ? ?
Hi !
How do I
Well, you could read in all your files and apply a filter with
_filename HAS (2).
This should reduce the list to the alleged duplicate tracks
Select all.
Now it should be easy enter any string in the comment field.
Or delete the selection.
Or whatever.
_filename HAS (2). doesn't work. Please tell me what I am doing wrong.
Thanks
%_filename% HAS "(2)" should do the trick.
sorry to all for the invalid syntax - apparently I was too occupied with getting the ide across
