I want to copy my sort composer tags to the composer tag:
Action type: Format value
Field: COMPOSER
Format string: %composersort%
but I only want to copy across names that do not have commas in them (i.e single surnames, no christian names or multiple composers)
weston
smith
ninja
etc.
not and tags such as
hansen, paul
apple, bob
ghost, mr
Is there such a thing as an "If" command I can insert?
Many Thanks
Steve 45
This one should do the job (please test):
Field: COMPOSER
Format string: $ifgreater(strchr(%COMPOSERSORT%,','),0,%COMPOSER%,%COMPOSERSORT%)
Functions are described in the help topic on Scripting.
To get an overview what tracks will be involved in your action, you can apply a Filter expression at first:
"$ifgreater($strchr(%COMPOSERSORT%,','),0,1,0)" IS 1
DD.20110503.1236.CEST
Many thanks to you both. Am about to try. Somehow after installing an update to iTunes, around 10,000 tracks lost their composer tags, still got the sort composer tags, but they are in a different format! I had just bought a backup harddrive a couple of days before and was just tidying up before backing up to it! Sods law I think...
Steve 45
