I'm just wanting some clarification with an $if2 statement.
/%dummy%/%dummy%/%dummy%/%CONTENTGROUP%/%dummy%_%dummy% - %artist%/$if2(%dummy%_%TITLE%_%DUMMY%,%TITLE%_%DUMMY%)
Filename 1: ES_Colliding_PN
Filename 2: Amsterdam_PN
I don't think I have the statement inputted correctly, as no tags are being written.
Scripting functions are not supported when importing tags from filename. The idea however is interesting, but I think it would make the format strings and the pattern matching involved quite complex.
Applying the format string at "Filename - Tag" is already a pattern matching problem and each conditional in the format string would branch to another pattern matching alternative.
Regarding a possible solution to what you're trying to achieve: you could import the last component of the filename to the TITLE field and use regular expressions to extract the part you want to keep.
