Hi!
I'm using the ID3v2.4 UTF-8 format to save my tags. This is because I want to see my comments in Windows Explorer (XP SP3).
The the problem is, that another program (SAM-Broadcaster) I am using isn't showing the saved images any longer. The cover images are visible in the 2.3 format but not in the 2.4 format.
Is there a difference in the image-format between ID3v2.3 and ID3V2.4?
Is there anything I can do to see the comments in the Explorer and the cover images in the broadcasting program?
Thanks for any helping answer!
(Sorry for my english!)
