Sometimes when I click on the image, it disappears, without being able to enlarge it, because the image has disappeared?
I managed to reproduce the image disappearance:
You'll see in my video that I managed to make the image disappear when I click on it frequently.
Why does it do this?
Does this happen to any file? Or just this one? (I can't reproduce it).
Could you supply such a file?
Thanks for reporting the issue! I was able to reproduce it by changing the click into an accidental image drag operation, where the image drops onto itself.
Investigating.
Hello @ohrenkino , it's not just one file; I can reproduce the bug with different audio files.
I tested it on two Windows 10 computers, one Windows 7 computer, and I recently bought a laptop with Windows 11. I'm having the same problem...
Thanks, @Florian , for testing
Yes, wih the more detailed description that it is not only a double-click to open but actually a little "drag", I see it too.
Thanks @ohrenkino for doing Florian test and confirming there is a problem.
I've just released Mp3tag v3.30a , which now detects those accidental drag and drop operations and prevents the cover from being removed.
Thanks for reporting!
system
Closed
July 14, 2025, 6:14am
8
