Can someone tell me how to remove the album images? I did something that repeated the same image for various mp3s.
Thank you in advance,
pmarouk
pmarouk
Select the files
Right-click on the image frame in the tag panel and
select "Remove image".
Repeat this until all unwanted images are gone.
You can filter for files that have 2 images with
%_covers% IS 2
You cannot select which image is deleted (first or second or other)
Thanks I appreciate the information!
